[Feature request] Last Sync column in Configuration window
randiskhan
Thank you for all your hard work on this great tool. Used every day for years.
For the way I use FFS, it would help if there was an easy way to zero out the "Last Sync" data for configurations. Optimum I can think of would be on context menu when right-clicking configs that are highlighted. Currently I do "Hide configuration" then reload them - A bit cumbersome.
Also an option for the "Last Sync" to be a full date/time rather than just a "days since" would be handy.
Thanks for listening!
