Feature Request for batch-use ...
volker01
Make an new Option to:
stop a running batch-job.
It can be very useful,
because kill a running batch-job,
remains the sync.ffs_lock files,
and the next run is very slowly.
Volker
You can. If you are running it minimized, you can restore the window from the icon and stop it from there. It would be cool to have a right-click>stop/pause option though
volker01
I forgot to say, ffs_batch is running over an Windows-Task - non-interaktiv (with user system).
In that case there is no tasktray.
The only way to stop ffs is to kill the task in Windows-Taskmanager.
Gotcha! If you are explicitly running as non-interactive, you are kind of creating the situation for yourself. You can have the task run "pathToFFS" "pathToJob" which will run it with a tray icon.
