Hi' :)
I have already moved a lot of data with the CCC tool.
Not i can' see that the FreeFileSync tool maybe is better for the job!
I have a more detailed LOG so i can see CASE-SENCE failures, and what files that have been moved.
BUT, what i need now for some shares - is only to try moving the »Extended attributes«
Is there a way i can set the app to do so - without moving all the data again - /20+TB
The CCC can do this - but it's getting stuck when trying - and would like to give the FreeFileSync a try!
Really need the extended attributes.
I'am sync'ing from NAS AFP share til new AFP-share (Acronis Files Connect)
Hope someone can guide me here :)
Extended Attributes...
Just tested some more... and noticed that if I make a complete sync, the extended attributes works.
BUT, if i change the the COLOR LABEL in the Finder at the source > re-sync - then the COLOR LABEL is not being updated at the target :/
