I did one task and everything was fine.Now i deleted that task and the batch file and made a new one in new location.
But after every restart, the program shows an error not finding this batch file in this location (show old task batch and location ,that one was I deleted ).The new task is with different batch in different location but RealTyme looking for old one (the deleted one)??!!
Sorry for my bad english.
RealTimeSync bug
You need to find where that RTS job is being started from upon startup.
Check:
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs"
"%homepath%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs"
You can also use something like Revo or autoruns to see startup items
Check:
Nothing there,only RTS and FFS shortcuts .How to find this RTS job?
There are many locations that the autorun could be located unfortunately. You may need to check registry keys or other locations
