Syncing files with a specific filename format
kolos123
I'd like to sync several files which contain "2019" and end with a ".docx" extension.
For example: 2019file.docx, my2019file.docx
I tried using : "*2019*.docx", but it doesn't work.
Appreciate your support!
You don't write where you entered/used "*2019*.docx"
When enter that as your Include filter (instead of the standard "*"), you should be OK.
