Android compatibility?
mikedsm
Hi Zenju,
I tried to create a Compare of files in my Android phone but FFS responded with "invalid folder". Since Windows recognizes the folders I wonder if there is any chance FFS could? Should I go put this in the Suggestions forum instead?
Thanks,
Mike
Unfortunately I cannot test this myself, but it seems there is some setting for Android to show drive letters in Windows:
[404, Invalid URL: https://sourceforge.net/p/freefilesync/support-requests/124/]
If this doesn't help then this requires special support:
[404, Invalid URL: https://sourceforge.net/p/freefilesync/feature-requests/141/]
mikedsm
Thank you Zenju! The first link was not my exact problem but close enough: In my Droid Razr Maxx I had to change the USB setting from "Connect as Media Device" to Mass Storage. After that I am able to run a backup from both the Internal and External SD card storage to my laptop. Yay! Thanks again!
