Simple renaming of the left folder
gugapq
Hello. Good Morning.
I really enjoy using the program but in case of a simple folder rename the program deletes all the contents of the destination folder and copies all the files again.
Got a setting for that?
thankful
Try out enabling Detect Moved Files in the synchronization Settings.
Unless you are changing the name of the left- or right-root-folder (as opposed to any of its subfolders), this should do the trick.
