I've been using FFS for quite some time.
Since version 10.18 FFS hangs while computing directions. Program/Processes can not be stopped via task manager and computer must be restarted.
After that, sometimes the first execution is successful, sometimes not.
Deinstallation with subsequent reinstallation did not fix the problem. No other software had been installed.
Any suggestions?
FFS freezes while calculating directions
I would check your hard drive health with Gsmart and run a chkdsk if it is healthy.
