SFTP sync in both directions?
xdev
before i download & install: is it able for SFTP sync in both directions?
xdev
and i also need it in realtime
FreeFileSync (FFS) supports SFTP, if necessary in both directions.
If the SFTP server(s) support the retention of file date/time (not all do!)
you can even use a comparison on size and date/time.
FFS does not support realtime sync itself.
However, you can run FFS as a scheduled task at regular intervals.
ReaTimeSync (RTS, that comes with the FFS installer) can monitor folder trees for changes, and upon detecting such changes launch e.g. FFS to run a specific sync.
However, normally SFTP servers do not support folder monitoring. This is not a limitation of RTS but of the (S)FTP protocol or server. So, very likely RTS is not an option in your use-case, and you would be stuck to scheduled syncs.
xdev
ok thx, where can i download realtimesync? can't see any download links..?
As already stated, RTS comes with (is included in) the FFS installer.
xdev
thx!! :-)
xdev
https://fullsync.sourceforge.io/ is not related with your product, it it another company..?
xdev
"FreeFileSync (FFS) supports SFTP, if necessary in both directions."
Can't see any remote space options in my version of FreeFileSync - just local ones:
Why?
Thank you for your feedback...
I don't know what you mean by "remote space options",
but (as indicated) you can use drag-and-drop for your left and right base location,
or you can simply type the protocol and address like
sftp://[network-ip-address]/[path-from-network-location-root-to-base-folder]
