Exckuding root files only
samthewebman
D is my data drive, G is my backup drive.
The mirror comparison specs are D: --> G:
I want all folders of G: and their subfolders considered, but would like to exclude ALL files in the root of G:. My reason for wanting to do this is that I place backup images in the root of G: and don't want them erased. I realize I could filter root files specifically, as *.tib, but I'd like a global exclusion that applies to all root files.
Thanks ... Sam
You can use an include filter "*\*" to only process files/folders located in sub-folders. See the help file on "exclude items"
samthewebman
You can use an include filter "*\*" to only process files/folders located in sub-folders. See the help file on "exclude items"Zenju
Zenju thanks for your post. That syntax you suggest is not listed in my help file. I'm using Version 5, Jan, 2012 build.
The exclude items section has nothing about this that I can see.
Thanks ... Sam
Then it's probably time for an update...
