Offset time has stopped working in 10.18
ernst.schnell
Hello all,
I am getting the impression that the "ignore time difference" when comparing function has stopped working in the latest update (donation edition). I have some files that have a limited time lag due to DST and other issues, and they are now being identified as different, although the difference is within the specified tolerance. Any ideas?
Thanks, regards and Happy Holidays!
Ernst
… I have some files that have a limited time lag due to DST and other issues, and they are now being identified as different, although the difference is within the specified tolerance. ernst.schnell, 20 Dec 2019, 05:24
Mind the Note in the purple text box in the Manual page on DTS issues.
This means your timestamp difference needs to be exactly the DTS setting.
If you have other timestamp related issues, you may try changing the FileTimeTolerance, which is a setting in the Expert Settings.
