Duplicate Files in different Sub-folders matched
Fight Duplication, compare file options to have only relative folders or search recursive folders, and allow to select which folder tree structure version to keep. I'd like to be able to spot duplicate files and select which folder structure works best and select that folder tree branch to be kept and matched with other dups found would be nice. Some type of feature that would detect the files to be compared to the other files, even if the folders don't match up, like if the file was moved to a folder to start organizing files. Maybe this is a separate tool/program, or option to move everything except duplicates found, or just use a different program to dedup, suggestions welcome.
Hi Eric, I was hoping you found a way to do that by now. If so, it would be very much appreciated if you could share your findings :)
Thanks in advance,
Cheers!
Thanks in advance,
Cheers!
