Selection of Duplicates by Folder Tree Structure Path
I think matching up the grouping and/or sorting ability to select the tagged copy of each group to use that path selected to mark/tag the other entries similar to that path before the filename. To add to the feature more you can delete the duplicates on say a folder merge scenario, to combine all transfers to one folder, and compare the DB of files for duplicates by hash. Really some good ideas on this forum.
