how to disable the use of ffs_tmp files
zcq0730
I wonder if we could disable the ffs_tmp files.
I am using FreeFileSync for archiving data into our server.
However, I only have the right to create files. I could not delete files. Therefore those ffs_tmp files remain.
Basically, I only need to copy files into the server. Do not need to do anything else. Like Robocopy.
I like FreeFileSync`s very intuitive user interface. Is there any possibility to disable the ffs_tmp files?
Thanks a lot!
It's in the options menu under fail-safe file copy
zcq0730
I disabled the option, but still, I got the following error. The FTP server does not allow me to delete files. Once it has been created, I could not modify or delete it from the server anymore.
