Mirroring Drives
Superquad1968
Hi folks,
Has anybody found a solution to this problem? When I try to compare two drives I get this message:
"Cannot open directory "E:\System Volume Information".
Error Code 5: Access is denied. [DirReaderPlus]
This problem does not occur when comparing two folders on the same drives. Obviously, I could just put everything in one folder on each drive and mirror the drives that way. When there is a problem, I like to look for a solution.
Thanks for all your advice,
Dave
filter out that folder. That holds your system restore points and you won't have access to it without extra steps
