Hi forum,
unfortunately, my account in the AllDup-Forum is not activated yet, therefore my (rather urgent) question here:
Is there a way to search for duplicates of folders only, for example using AllDup (regardless of the folders' content)?
Thanks for help :o
find duplicate FOLDERS only, not files
No way using AllDup, instead try V Folder Dups, an obsolete software that you can still download from Softpedia https://www.softpedia.com/get/System/File-Management/V-Folder-Dups.shtml
Great Gianni, will definitely try this one!
Unfortunately, I have a situation where both the name and some of the content of those duplicate folders could have changed (at least slighly). I therefore should actually be able to find folders that are "most similar" to each other regarding their content...
