Error:0x80070057 from iphone sysnc to pc
xiaoji
Hi,i use FFS copy image from iphone to pc ,when ffs copy files,it results a error:
无法打开文件(can't open a file) "mtp:\iPhone (3)\Internal Storage\DCIM\100APPLE\IMG_0001.JPG".
Error calling "resources->GetStream(objectId.c_str(), WPD_RESOURCE_DEFAULT, STGM_READ, &optimalBlockSize, inStream.init())".
HRESULT: 0x80070057, 参数错误。
the path exists (mtp:\iPhone (3)\Internal Storage\DCIM\100APPLE\IMG_0001.JPG),i have check
xiaoji
the ffs version is 10.19
os system:win7 x64
Are you able top copy this file manually via Windows Explorer?
For reference: 0x80070057 == HRESULT_FROM_WIN32(ERROR_INVALID_PARAMETER))
xiaoji
Are you able top copy this file manually via Windows Explorer? Zenju, 26 Jan 2020, 22:26
yes,i can copy or open this file manually,
xiaoji
by the way ,i use ffs to copy iphone image with two different pc,ffs came the same result
Can you you navigate to this file with the following tool and post a screenshot? This should give some additional insights:
https://www.mediafire.com/file/esuors6i88u1ahf/WPD_Tools_32-bit.rar
