Sync Failure Based on File Size and Time
drveresh
Ver: 7.0
I just found serious bug that the same files with same greater time and size in same folders is being marked wrong movement changes.
Ex: I have File1.txt in Left folder date is most recent and Right side file is 2 months old and both in same size, but it suppoed to move/sync from Left->Right, but marking Right<-Left.
What is going on?
Also, the sync between Mac and Windows using common USB is bringing lot of bugs and issues.
wm-sf
you need to provide more details.
are you perhaps using a USB drive as an intermediary between systems? that might explain things
When using "two-way" variant, FreeFileSync will propagate all changes, so if you overwrite a newer file on one side with an older version and then start synchronization, FFS will propagate this change, irrespective of which file is newer.
