I noticed since last or one of the latest versions that the icon in the system tray is not visible when a scheduled batch job starts, in a specific case, even if the batch job works correctly.
The icon appears only if in the scheduled task the option "Run only when user is logged on" is selected, while when the option "Run whether user is logged on or not" is selected the icon does not appear.
I'm using v. 10.19 and I'm pretty sure one or more versions ago the icon was always visible in system tray during the tasks with the option "Run whether user is logged on or not" selected.
Can't see icon in system tray with a scheduled batch job
There hasn't been a change as far as FFS is concerned.
Ok, assuming it has always been this way, why if in the task configuration I select "Run whether user is logged on or not", the icon in the system tray is not visible when FFS is executing the batch job?
It could be a bug?
It could be a bug?
Could it be that you run your scheduled FFS batch job under different user credentials?
No. I also tried with "Run with highest privileges" selected or not.
Someone can replicate the issue? It's enough to select "Run whether user is logged on or not".
I tried on 2 phisical pc and on 3 virtual machines and the result is the same, the icon does not appears in the conditions described above.
Any feedback?
It is not possible to make the icon visible also with the option "Run whether user is logged on or not" selected? :-(
Something new about this issue that occurs yet? Has it been investigated about it?
