Sync with another computer
How can I set up to sync a file from my desktop to my laptop? They're on the same network. When I browse, I can click on "network", it shows my laptop but doesn't show the drives and directories. Any help? Or does this software not do this.
FreeFileSync (FFS) should be able to do it.
You can simply drag+drop the applicable remote base folder to your left-right folder pair.
Did you watch the tutorials on Mirror and Two-way syncing?
You first need to setup a shared folder on the desktop that you can map on the laptop, then sync
@xCSxXexon
Mapping is not required, you can also use an UNC description.
In both cases you can use drag/drop.
