Dear community,
i have a sync batch saved with two different folderpairs to sync. But both are not always connected to the PC (1 USB Stick and 1 SD card reader).
I want RealTimeSync to force sync of one of them, even if the other one is not connected. Right now, it syncs only automatically, if both are connected at the same time.
How can this be solved?
rgds, Holger
Forcing RealTimeSync to start Sync even if Folderpair missing
You'll have to create two separate RTS packages for that
