FTP Sync Error
charlesdab
Hi All-
I apologize if this is a simple question, I've hit a wall trying to troubleshoot this. I'm trying to sync ~2.5TB from a remote server to my local directory. While FFS processes all the data, it doesn't process the files. I've been getting a couple of different errors. I just tried making a one item sync to test it.
When it "Completed" after about two minutes this was the error:
Cannot read file "ftp://RemoteServer/UserName/Users/UserName/Videos/- MOVIES/Movie Name (1998) 720p.mp4".
CURLE_RECV_ERROR: OpenSSL SSL_read: Connection was reset, errno 10054
FTP status 150. [curl_easy_perform]
Anyways I would really appreciate it if you could spare the time to help me out!
Thank you.
Spiderchristian
Had the same issue today... did you found a solution?
charlesdab
Had the same issue today... did you found a solution? Spiderchristian, 15 Jan 2022, 10:01
Nope, I put it down after that post and never tried again.
