Hi all,
Attaching in image my current setup that is synchronized via google file stream.
I configured "freefilesync" batch job at each PC, with realtimesync which keeps the PCs & google drive synced constantly.
Running on Windows.
The current configuration works well at most of the time.
In the google file stream folder I can see that the file "sync.ffs_db" exists
In each PC I can see that the file "sync" exists as well.
But sometimes, i'm seeing some issues and wonder if that can be solved with better configuration.
*The likelihood that the same exact file in path will be modified on more than one PC is very very small.
The issue that i'm seeing is that sometimes, which I cant still point what caused this behavior is that a duplicate folder or file is created i.e "folder_name (1)" / "file_name(1)" …
The working flow is described below:
PC1 is in testing progress and creates a report folder with unique serial number which contains file&folders.
PC2 as well
PC3 …
Then freefilesync is syncing all the new unique SNs folders that were created to google file stream folder.
than each PC is synced with google file stream to have the report folder that created on the other PCs.
thanks
Sync multiple PCs with Google file stream
