Just downloaded 10.20.
Ran the install routine. It gets about 10% of the way through and then says it can't create a file that already exists.
The file it apparently can't create is FreeFileSync.exe!
It's apparently created a file that I can delete, rename, or remove in any way. I suspect something weird has happened with a previous installation.
Please advise.
Install fails
Check AV.
AV is fine with it. I had to download lockhunter to delete the file on reboot before I could get rid of it. It said that FreeFileSync.exe was running under System, which is why I couldn't delete it.
I've now managed to install successfully, but..
I made a donation before downloading, but I don't seem to have the "donation edition". Clicking on the button to get it does nothing.
I've used Lockhunter on it again, and it's now apparently running in its own context, not under System.
