Empty Folder Compare error when Filtering by max size
fblaha
I have an include filter of *, but limiting to a max file size of 100 Mb (min size filter disabled).
When the max size filter is enabled, empty folder are not getting synced (deleted),
But when I disable this filter, comparisson is ok.
This is a bug I suppose, is there a workaround?
Thank you.
Not sure what you mean exactly, but
... empty folder are not getting synced (deleted)
FFS never deletes folders; it only deletes files (when relevant to the sync).
FFS never deletes folders; it only deletes files (when relevant to the sync). Plerry, 20 Feb 2020, 08:06
FFS does delete folders. The problem here is that the file size filter, once enabled, only matches files and not folders (which arguably have no size).
fblaha
Hi Zenju,
so it is a bug right? Any suggested workaround in the meanwhile?
Thanks.
No, it's not a bug, but the current design (which can be improved, maybe).
