error 0x2
mazimo
FFS has been giving me this error for a few days
Unable to set directory locks for the following folders:
Could not write file "C: \ Users \ rober \ Documents \ My Documents \ sync.ffs_lock".
Error code 0x2: The specified file could not be found. [CreateFile]
on some folders that previously worked correctly; other folders work without error
gwagnerx
same problem applies to me when I try to compare my OneDrive
mazimo
idem miei problemi con cartelle in OneDrive
idem ...my problems with files and Folders in OneDrive
gwagnerx
I have to add, that this error only appears since I installed the update to version 10.20
Could not write file "C: \ Users \ rober \ Documents \ My Documents \ sync.ffs_lock". mazimo, 28 Feb 2020, 12:38
Do all these spaces really exist in the original error message?
gwagnerx
not in my case.
There are no spaces.
If I were able to upload a JPG or embed it in the text I'd have added the original error window.
mazimo
no non esistono gli spazi....frutto del copia/incolla
