synching two different drives
dunk01
what happens if I ignore the message "Cannot write file "C:\sync.ffs_lock".
Error Code 0x5: Access is denied. [CreateFile]"
See the LockDirectoriesDuringSync description in the Expert Settings section.
Gianni1962
Normal users cannot write to the root folder of the system drive C:.
You can start FFS as Admin but it is better you revise your sync strategy specifying the folders you want to sync both left and right sides.
