while syncing there is a window.
How can I set the command:
<When finished:> "quite" permanent - by default?
Thanks.
Rolf
quit when finished
Hi Guys,
so it is not possible?
Simply select the desired options when saving your sync job as a batch-sync.
Hi Plerry,
unfortunatly that is not an solution for me.
At the beginning I would like to see/check what exactly will syncing.
So I need the overview at the beginning, but when syncing ist started it shout close automaticly.
That is what the "When finished = quite" does.
Well at the moment I have to write it every time manually.
Is the no ini-option or something else?
Would it be a opurtinity for the future?
regards,
Rolf
regards,
Rolf
