I struggling to make it work for me.
I have FFS (v10.20) and Visual Studio Code (v1.43.0) installed on macOS Mojave (v10.14.6) and would like to add a file compare context menu command, so
#1: I added Visual Studio Code to my path as explained on their site:
"Open the Command Palette (F1) and type 'shell command' to find the Shell Command: Install 'code' command in PATH command."
After this, I am able to launch Terminal and run:
code --diff <file1> <file2>
#2: So I added the following option to FFS at 'Customize context menu':
Description: Compare with Visual Studio Code
Command line: code --diff "%local_path%" "%local_path2%"
So far, it does nothing. No errors. No windows opened. Why?
Thanks for your help in advance!
Craby
macOS file comparison with Visual Studio Code
I found out the solution myself, I hope this will help others, too:
The solution is to configure Visual Studio Code as external file compare (diff) tool in FreeFileSync as follows:
Command line: /Applications/Visual\ Studio\ Code.app/Contents/MacOS/Electron --diff "%local_path%" "%local_path2%"
Note the backslashes (\) to escape the spaces... without these it fails silently.
Enjoy!
Craby
Enjoy!
Craby
Thank you for sharing the solution! It makes a lot of sense in a Unix-based platform that you would need to escape the spaces, but not everyone will know to do that.
Errors are not reported because the command is run asynchronously. Only when starting more than 10 commands FFS will show a warning and run them one after another => bonus: if an error occurs it will be notified.Description: Compare with Visual Studio Code
So far, it does nothing. No errors. No windows opened. Why? Craby, 16 Mar 2020, 19:38
Anyway, I tried to reproduce the issue, and at first I also wasn't able to run "code --diff". I made some code changes, and suddently it worked! Then I reverted these code changes, and "code --diff" *still worked*. So I suspect there was a buffering issue, or a permissions issue (I believe VScode asked for file access permissions once and I granted them).
