Cannot write file/Cannot open directory
Piotrek94
I have a problem with error:
Cannot write file "\\Nas326\...\sync.ffs_lock"." ERROR_PATH_NOT_FOUND [CreateFile]
Also if I ignore it, another error comes up:
Cannot open directory "\\Nas326\..." ERROR_FILE_NOT_FOUND[DirReaderPlus]
The problem is quite strange because firstly, I installed the standard version 10.20 and it worked fine. I was worried about bad performance so I donated and downloaded 10.21 [donation edition] version to use the performance improvements option. Once I installed the donation edition I started to have problem with the abovementioned errors and can't proceed with my project. Well, I thought that it could have been caused by installing the donation edition because problem started right after I started using it, however I can't even compare folders now using any of the available editions.
Also I read that it may be caused by permission problems, yet I can't find a way to check if that's the case. I am still able to modify, write or open the files on my NAS326 local server so I don't know why FFS can't do it now.
Anyone knows what might have caused this issue or how to solve it? I couldn't find solution on the forum.
Piotrek94
Well the issue solved itself... I updated to 10.22 and it works just fine.
