Installation files defect
Good2know
After installing Donation Edition, error message at start notifies installation files are defect.
Even after deinstalling/removal and restart, it does not work (note: version 10.19 works).
Good2know
Thank you for quick reply.
I guess I need the KEY file too (by Email?) or the version 10.22 fixed.
Have a Safe Time!
Hesket
I have had the same problem today - both the Win Portable and the Win Setup files are the same and will not install - help would be appreciated
