Hello there
I'm trying to sync from a mapped network drive to a local folder on my Windows 10 Machine. There are around 10 new files to be synched every day. I execute the synch-command manually, which works fine for me.
If the file exceeds something around 60MB, the file won't be synchronized and I recieve the following error message: "ERROR_FILE_TOO_LARGE: Die Dateigröße überschreitet die maximal zulässige Größe und kann nicht gespeichert werden. [CopyFileEx]". The german part is translated into "The file size exceeds the maximum allowed size and cannot be stored". Besides that, there isn't anything in the log files.
Now I didn't set any limitations on the FFS-side in regards of file size (attached). I have more than enough space on my SSD. Mostly there are just small documents, which are being synched without any issues but since Covid-19 I have to synch videos from online lectures (mostly around 500-800MB). I couldn't find anything similar in the forum.
Otherwise FFS just works perfect. Thanks in advance!
That sounds like a separate issue. Can you manually copy the files fine?
Yes, every time without any trouble.
The problem lies with WebDAV itself. It allows max file size of only 50mb by default. It needs some registry editing to solve the problem: https://docs.kentico.com/k10/managing-website-content/configuring-the-environment-for-content-editors/configuring-webdav/webdav-requirements-and-limitations
