I don't understand what the overview represents. Is there an explanation? What
do the %s mean? Thanks
Overview ?
Well, it's ... and overview on the grid data. After comparison it should be
clear what it represents. You can also do a directory analysis by specifying a
single folder only, e.g. the left one, and leave the right folder input field
empty, then press compare. The effect will be the same as in other directory
analysis tools like WinDirStat.
> What do the %s mean?
I have no idea, where do you see a "%s"?
