Added MacOS Icon files to Exclude list, but they are not being excluded
Hi! I have added */Icon to the Exclude list, but the Icon files are not being excluded when the comparison is performed. Other exclusions work fine, but this particular one doesn't. Is this a known issue?
I don't know the file naming and location convention(s) in MacOS, so I can not assess the correctness of your Exclude specifications for Icon files.
However, if you run a Compare, the list should show any Icon files not (yet) excluded by the Exclude filter.
Simply right-click on such an Icon file, and let FFS add it to the Exclude filter.
You can then open the Include/Exclude filter setting and learn how FFS has excluded the(se) file(s).
I actually added them to the Exclude List, using that method. I did not add them manually. But they keep staying in the list of filed being compared after that. It's pretty weird.I don't know the file naming and location convention(s) in MacOS, so I can not assess the correctness of your Exclude specifications for Icon files.
You can then open the Include/Exclude filter setting and learn how FFS has excluded the(se) file(s). Plerry, 10 Apr 2020, 10:20
