Auto Sync?
michaelinthenow
I recently switched my Windows 10 install to a new drive. I had to reinstall FreeFileSync and re set up my scheduled synchronizations. However, it only opens and compares files, it doesn't actually synchronize. I have to manually sync the files. It worked before the reinstall.
I've gone through the tutorials but I can't see what I'm doing wrong.
Help?
Did you save the sync jobs as batch files?
michaelinthenow
Yes. I have two batch files. One for a local back up and one for a Google Drive back up. Is there a setting in the batch file I'm missing?
Not that I am aware of. I have never seen it perform a compare then just stop. It may be worth rebuilding a config and testing that
michaelinthenow
Ok. I'll give that a try.
