Miror mode > How to delete AFTER copy left to right
Hi, in mirror mode I want to delete all the left files which are not any more on the right side ONLY after all the right files which are not on the left side are copied on it. How could I proceed ? Best
Sounds like you want "Two-way" not mirror
S...., I previously mixed right and left side :-(
I want to export a backup (around 300x1Go encrypted files) to a SFTP volume and I want to keep the RIGHT files until the new backup is entirely on the right.
Gotcha! You can run an update and then a mirror. This will add left files to the right without deleting anything on the right. Then you can run the mirror, which won't copy anything else since it's done already, so it will just delete files on the right.
Fine ! Thank you.
