Need help by using a Samsung S20+ that has to be backed up to an external HDD secured by Bitlocker. The HDD is unlocked at the moment. I get this error:
14:45:19 Fehler Die Datei "mtp:\Galaxy S20+Micha\Card\vm android\Screenshots\20200117_082833_1579261232945.png" kann nicht geƶffnet werden.
Fehlercode 0x802a0006: Der angeforderte Wert kann nicht ermittelt werden. [resources->GetStream(objectId.c_str(), WPD_RESOURCE_DEFAULT, STGM_READ, &optimalBlockSize, inStream.init())]
Anyone with a suggestion?
Can't use FFS with S20+
The error code 0x802a0006 has been accidentally assigned twice by Microsoft:
0x802a0006 == UI_E_VALUE_NOT_DETERMINED == E_WPD_DEVICE_IS_HUNG
So the real error is "E_WPD_DEVICE_IS_HUNG". Google indicates that if the MTP disk is out of space that can lead to this error, but there are probably other reasons, too.
