syncing multiple folders in different mode?
sfmaniaque
hello all,
thx for your work, your soft seems great and i am going to adopt it!
i am new so excuse me... i've searched a little bit and not found some answer to my question
i would like so sync folders in a different way in the same time
is it possible to sync one folder in mirror mode, and in two sides mode for another folder, and put that all together in the same batch file?
or should i do 2 batch files?
or should i make an hybrid batch file by editing the xml file and modify it manually after i saved it in one sync mode only, to add the second mode ?
thx for your expertise
sfmaniaque
found my answer!
save the batch files separately in the FFS window with one batch in two ways and the second one in mirror by example
then select the batches files one by one with the CTRL key and save one batch file that i insert into the RTS!
great tool you made guys!
and i tested, it works perfectly... one is indeed in mirror mode, and the other is int two ways mode!
thx a lot.
Or, in one and the same sync, you can define multiple left-right base folder pairs.
For each of such multiple pairs, you can define local sync- and/or filter-settings (using the corresponding gear or funnel icon in between each pair).
