I run a batch backup every day at 00:05am. It has run perfectly for some time until yesterday when it just did not run. I opened up the GUI and was met with an "upgrade available" message. Is it possible that this message is still triggered during batch runs? I turned off the "check automatically (for updates)" option and it ran ok again last night. There was nothing in the FFS log either.
It might just be a coincidence but nothing else on the system has changed.
Cron initiated Batch run suddenly stopped.
The update checks are off in batch mode.
I assumed that they would be and was clutching at straws. It is still working ok. Strange for sure.
Thanks for the reply.
