Error while Scheduling sync on remote location, like GDrive
Julien
Hello everyone,
I have some issue with tasks scheduling.
When I use the scheduled task to sync folders that need specific access rights, I get some errors.
The same task run under the GUI work perfectly. I managed to make it work by running the task with a user having access to the shared folder.
However, with Google Drive, it does not work as I cannot use this workaround.
The task runs perfectly under the Gui. When I save it as batch and run it with the task scheduler, I always get such errors:
7:15:34 PM Error: Cannot find the following folders:
gdrive:\sp***erATgmail.com\Eu****ia
Cannot read file attributes of "gdrive:\sp***erATgmail.com\Eu****ia".
Please authorize access to user account "sp***erATgmail.com".
7:15:59 PM Error: Cannot read file attributes of "gdrive:\sp***erATgmail.com\Eu****ia".
How to actually save the credentials for the task run properly under scheduler?
Thank you!
