RealTimeSync on file
How do I get RealTimeSync to run on when a specific file is changed and not any file in the folder?
You would have to put that file in its own folder
another possibility is that you filter all other files.
You can't filter in RTS, so it would still run a sync every time any file would change in the directory, even though a sync would only find something to do when that single file is changed. It will still run, but not do anything
