Copy only Folder Structure
elchico
Hey everybody,
I wonder, if it is possible to copy only the folder structure? So I have only a copy of the foldes without any files?
Thanks.
Michi
Not aware if FFS can do this, but you can achieve this in cmd prompt super easily
https://www.winhelponline.com/blog/how-to-copy-folder-structure-without-copying-files/
A one-off solution is to sort by time or date, which moves all folders to the bottom. Then exclude the files at the top.
elchico
I am aware of the cmd solution, and it is easy but more complicated than FFS ;-) thanks anyway.
I did it the Zenju-way and it worked perfectly. Thanks!
