I downloaded I followed the guide to setup RTS as a window service. I started
the service and everything worked fine but it only run once. The service never
executed RTS when I updated source folders. I restarted the service then it
worked again but not on the next updates on source folders.
Any idea what I'm missing here? Thanks in advance for your help.
Run RealTimeSync as service
I would first try to test RTS without setting up a service. If you find, this
is working as expected, only then setup the service. For trouble-shooting it
is a good idea to enable checkbox ""Allow service to interact with desktop" in
the Service properties. This way you will see if a popup dialog stops the
progress.
Generally, if you are on a single-user machine, it is a better idea to simply
put a link to RTS into autostart than to setup a service.
progress.
I am also facing a similar problem, and I have tested it with RTS without
setting up a service and it works fine, however it does not work seamlessly as
a service. If I restart it runs once and agains stops synchronizing. No window
is popped up and no error is logged and the service is not stopped. I can
notice that RealTimeSync_win32.exe is not running after the service is
restarted and the synchronization is completed once. Free
What could be the possible problem? Awaiting your help and advice, Thanks !
In the helpfile for the next version I won't be recommending the "service"
solution fo RTS anymore. It creates way too many problems, and there seems to
be another, simpler solution: Just use Windows Task planner with the SYSTEM
account:
viewtopic.php?t=728
account:
viewtopic.php?t=728
