FFS 10.24 not working on Arch: VERSION_ID missing
TB0815
I installed the latest version of FreeFileSync. This version should work with the /etc/os-release file, which is available on ArchLinux. Arch is an rolling release distribution and does not have a version in this file!
NAME="Arch Linux"
PRETTY_NAME="Arch Linux"
ID=arch
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://www.archlinux.org/"
DOCUMENTATION_URL="https://wiki.archlinux.org/"
SUPPORT_URL="https://bbs.archlinux.org/"
BUG_REPORT_URL="https://bugs.archlinux.org/"
LOGO=archlinux
So, I got an error if I try to start the new release: VERSION_ID missing. [/etc/os-release]
How can I fix this? Thanks.
Fixed! I've just updated the FFS 10.24 Linux release accordingly.
TB0815
Yes, it's working! :) Thank you
bgstack15
Would you please check the status of taskbar.cpp from the most recent source update, Zenju?
Would you please check the status of taskbar.cpp from the most recent source update, Zenju? bgstack15, 17 May 2020, 19:11
Also fixed, thanks!
bgstack15
Thanks, Zenju! I had failed to do a basic file lookup in the repository to see that it was in a different location.
