Sync with some only-files in folders
jose_a_mald
Hi, I want to sync several folders to my external HDD, including everything in my OneDrive folder (I know, they would be stored in three places, possibly an overkill).
My problem is that some of the files on OneDrive are online-only, and when I try to sync the whole OneDrive folder to the external drive it triggers a download for those files. I'm talking about hundreds of files, so excluding one at a time is not an option. Is there an option so FreeFileSync can ignore all online-only files so they don't download when I start to sync?
Not possible unfortunately. Native support for OneDrive would need to be added.
jose_a_mald
Thanks for the answer, even if it's not the one I would have liked.
IsaacEthan
Not possible unfortunately. Native support for OneDrive would need to be added. xCSxXenon, 27 May 2020, 17:13
it will be great if this feature add, waiting 🙂
