batch wil not run with task scheduler
johan
i have windows server 2016 and i create a task with a batch and it wil not work
task scheduler cannot find the bacht file
i used the mannual in freefile see attachment only i don't used d:\ drive but i used c:\ drive
Can you verify the location of your ffs_batch file?
johan
Yes i can and he is in this folder c:\backup see screenshot
when i mannual clik the file he is working perfect
Looks like the path needs to be "C:\Backup\backupnas1.ffs_batch"
You have "C:\backup backupnas1.ffs_batch"
johan
it works now thanks
