Sync Path with blanks inside
fjuecat
I would like to sync lokal files to my Onedrive folder, but this folder contains blanks (the can't be deleted/changed). I tried to enter the sync path like this with quotation marks: "...Onedrive Business ..." buts this also doesn't work.
Does anybody know, how to enter such a path?
Thx
Jürgen
bgstack15
Spaces sometimes can be escaped with a backslash \ character in front of the space.
So that is a backslash followed immediately by a space. See if that gets you what you need.
Are you sure that is the issue? I also sync to/from the local OneDrive folder, with spaces, and have no issues
