HarddiskVolumeShadowCopy - ERROR_FILE_NOT_FOUND:
rbeavers
I have tried everything I can find on this error, still nothing solves the problem. FFS is running as Admin, I have enabled "Copy Locked Files". FFS creates the ShadowCopy as it should. When the ShadowCopy files are being copied, many if not all of the copied files will error. See below...
10:47:20 AM Error: Cannot copy file
"\\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy22\ProgramData\Microsoft\Search\Data\Applications\Windows\edb.jtx" to
"Y:\ProgramData\Microsoft\Search\Data\Applications\Windows\edb~4ca0.ffs_tmp".
ERROR_FILE_NOT_FOUND: The system cannot find the file specified. [CopyFileEx]
This problem has been going on for a very long time. I was hoping in each new update that somehow this would have been identified and fixed. This forum is my last resort. Any help would be greatly appreciated!
rbeavers
The error has started occurring again...
1:37:12 PM Error Cannot copy file
"C:\Windows\ServiceProfiles\LocalService\AppData\Local\FontCache\FontCache-Obsolete-609.dat" to
"Y:\Windows\ServiceProfiles\LocalService\AppData\Local\FontCache\FontCache-Obsolete-609~8eed.ffs_tmp".
I am currently running FFS 10.25 [Beta] 64 Bit. 05/31/2020
