FFS Avoid Moving File in The Trash
citizen8
Is it possibile to tell FFS to delete files and folders on the fly without moving them in the trash? I am using the latest version of FFS. Thank you for the time.
Simply select the desired Delete Files method in the Synchronization Settings window.
For you, the desired setting seems to be Permanent.
