Sync files only not directories
uri2510
I use FreeFileSync on Linux (Ubuntu), version is 10.24
Is there an easy way to sync only one or two files in a directory? FFS only lets me choose folders for syncing.
My problem that there are 2 files I daily update and I need them on GoogleDrive. But the folder where they are located also has 20 subfolders and I don't want / need to sync all these folders.
Thanks for your help.
Best regards Ulf
Run a Compare, identify the two files you want to sync, and via right-mouse click add these two files to your Include Filter.
Alternatively, you can edit your Include Filter manually.
uri2510
Thks for the fast answer
Ulf
